Incrimental lifting
Utah
At what point does a body lift become the lift of choice?
For small lifts you can use springs or go cheap with shackles. But I haven't seen much more than a 4" lift spring. Then you can get 2" lift shackles (4" longer than stock),... at what point do you have to dive into a body lift?
Not that I'll ever lift my DD that high, just curious.
I looked into it. Its the easiest way to get 35's under your truck without them rubbing. Thats in addition to a suspension lift of course.
So... lets say you've got 3" OME kit, 2" longer than stock shackles F/R, and a body lift- why not just SOA?
How long do extended shackles have to be before you don't have the correct geometry?
Well if you already have a OME 3", doing a SOA makes it pretty dang tall. Another reason to go with a body lift is that it can easily be converted back to stock form. Your steering geometry question is over my head.
