In serious need of some guidance about my tcase
Calgary
The front seal on my tcase was leaking so I removed the transfer case and the front extension housing to get at the seal. I have everything apart, but I did not pay attention to where the old seal sat in the housing mostly because every other seal I have seen has a little lip to tell you when to stop. Thus I dont know how far to press in the seal because there is no lip to stop the seal - I could press it all the way down to the bearing if I wanted to. So how far should it be pressed in?
Also, there is the slightest bit of wear from the the old seal on the output shaft - barely perceptable with my fingernail. I could press in the seal so that it does not ride in this ring, but how far and should I? I have about 2mm of play where I could place the seal, but frankly placement would be guessing at best because there really is no way to determine if its placed.
Your advice is greatly appreciated.
How difficult was it to remove your T-Case? I think I may have to do the procedure and I am not sure what I am getting into, did you have to remove the exhaust? Is there anything tricky or special tools that are required?
Thanks
The tcase was not hard to remove, except that it weighs about 75lbs. The only tricky part was getting the wiring harness disconnected - they are both waterproof and childproof, if you know what I mean. I did not remove the whole crossmember, I removed all but 2 bolts on one side and am currently using a jack to support the back end of the tranny. There is no need to remove the exhaust.
Sounds good, I am just replacing - not rebuilding the T-Case. The wiring harness, is that where the center dif switch is connects?
Well, they are plug-in connectors, but of the usual Toyota variety that are immensely hard to get to and undo. Plus I have big hands so that makes it just that much harder to do.
