Hello all!
This is my first posting so please forgive me if I am not detailed enough. I recently purchased a 89 FJ62. For starters, I love this vehicle. I had to put nearly 1500.00 dollars into this vehicle just to stop the leaks....and wouldnt you know it, the check engine light comes on two days later. The code its throwing is code 11 momentary interruption in power supply to ECU. Ive taken it to several mechanics and no one can tell me where this is coming from. Everyone simply wants to start throwing parts at it. Being out 1500 already i am reluctant to do so without even fixing the problem. The in dash battery voltage meter is jumping back and forth occasionally and when rolling down the window with the lights on it nearly drops to 0 but idles fine. The other day the truck was fine the RPM was ideling at 1000 and I turned on the lights and the truck voltage dropped 0 stalled and came back on. I had the alternator check and was told it is fine and charging the battery.
Any ideas. Thank you in advance
