I have everything disassembled on the passenger side at this point. My plan for today was to get both sides disassembled, let the birfs and bearings soak in mineral spirits over night, then reassemble both sides tomorrow.
I locked the center differential, jacked up the passenger side of the truck with the drivers side tire on the ground, and took everything apart. I didn't think as far ahead as to when I went to do the drivers side that there would be nothing to keep the axle from spinning.
On the FAQ post there are a couple pictures of people soaking there birfs at the same time. Is there some way to keep the axle from spinning if you don't have a front diff locker?
Also is imperative that the axle slide back in the exact same position it came out? I might have screwed that up when I spun the drivers side rotor when I went to start disassembling and realized the predicament I am in.
Also the outer wheel bearing just fell right out of the hub/rotor but the inner wheel bearing is stuck in there. Is that how it is suppose to be?
Thank you
Thank you
