Oll Leak:
My 1986 FJ60 has the nickname “Leaky” for a reason I have spent lots of time chasing down leaks and replacing gaskets etc. Here is one that has me confuzzled.
I get a leak that appears to be coming from the rear main seal which I replaced last November. The oil only leaks when the motor is running and it is most noticeable during a long trip. I will lose about 1/2 a QT every 700 miles or so and everything from the back of the flywheel, clutch+bell housing, tranny and drive shafts get covered in oil (I mean rust proofing ... ). Here is a list of work I have done which has not as of this date solved the problem.
1) Replaced Oil Pan and Gasket Gasket
2) Rear Main Seal w/ clutch job
3) Rebuilt T-case and all gaskets during a H55F install
4) Edit: Threaded Oil Galley Plug Installed between cyl 5-6
After the oil pan and gasket install there were no more leaks while it is parked so the only thing left is a seal that is exposed to oil with the vehicle in motion.
The bottom of the front of the oil pan has a bit of oil seepage but when I drive on a fine dusty road there is not evidence of oil getting on the oil pan itself so I am ruling that one out,
My best guess is that when the rear main was replaced, the seal was not put in properly or was torn.
Any other ideas???
I plan to drop the tranny over the next weekend and replace the Rear Main (Again) in the hope that that is the problem.
Thanks
Mark
Any other ideas???
Thanks
Mark
