I'm clueless!!!
Ok, the TLC is running like a cylinder is dead, but I disconnected a couple of connectors(injector or spark, not sure on this motor)... and it still runs the same. I can't imagine there's two or more that aren't firing, but I suppose that's possible.
Any ideas how to track this down?
Trunk Monkey
Moderator
Salt Lake City
Going to do that in the AM. Probably going to pick up a code reader as well, now that both of our cars are OBDII. I had a Nissan Consult for my 300ZX, but got rid of the Z and got a G35, so I might as well have a reader since it will work on both cars.
Do you have a check engine light on? You'll notice several threads recently referring to dead coil packs, sounds like you're the next one. If you've got a CEL, have the code pulled and see what it is. If it's p030x, x is your cylinder that's not firing. You can use this method:
https://forum.ih8mud.com/100-series-cruisers/266495-where-number-3-cylinder.html
to check that it's the coil pack.
The TPS one bugs me, because it's been driving fine after I replaced it not long ago... but cleaning the TB can't hurt. Spark plugs have roughly 30k miles on them, but replacing them is cheap.
I need to determine if it's a coil pack that's causing the problem. I think I'm getting multiple cylinder misfire codes because I pulled a connector while it was running yesterday to see if it made a difference - really need a code reader for that.
replace spark plugs and TPS and dont forget to clean the throtlebody
you all ready pull p0300 thas means random missfire on cyl #1 and #5 if you wat to check the coils just swap coil 2 and 4 to Cyl 1 and 5 and off cousrce coil 1-5 to cyl 2 and 4, clear the cel and drive if the CEL cmos back and you have p0302 and p0304 tha will confirm tahat the coil are bad
Thanks. I'll probably sit in the Autozone parking lot and swap the coils around. #1 is probably there because I pulled the connector last night trying to determine which cylinder was causing the problem, but I'll swap it around as well just to be sure.
Thanks
Naturally it was the coil pack on #5. The code indicating #1 was bad was because I'd pulled a connector while trying to troubleshoot before. Anyway, problem solves - thanks guys.
