IH8wire
Discussion in '40- & 55-Series Tech' started by Plowboy, Jul 20, 2005.
  1. Plowboy
    Plowboy
    798
    3
    Apr 21, 2002
    On a hill overlooking a lake in Idaho
    IH8wire PROBLEM FOUND
    Started having a problem with my starter. At first nothing happened when turned key to start. Then When it did start the starter kept running. Had a very similar problem about 15 yrs ago. Replace the switch wire at the steering wheel,(found lots of brass shaving in the switch) Problem solved. So figuring the switch had worn out again, put in a new switch. Problem solved for about three days, then problem started again. Turn the key to on and the starter would engage and continue to run. Figured I got a bad switch from Toyota, so pulled apart at socket and check current through wire. Everythng at the switch was working. Started checking other places and found the terminal at the starter was becoming hot with the switch in "on" position. NOT SUPPOSE TO HAPPEN!!! Which means to me, some place I got a crossed wire, but the starter wire is suppose to be direct from the key to the starter. Not looking forward to cutting the harness apart to find the crossover, but don't know of another option. Any suggestions, other than use a sharp knife?
  2. Mace
    Mace rock scientist.. Staff Member s-Moderator
    21,701
    2,145
    Feb 17, 2002
    Las Vegas
    be careful with a sharp knife.
    sounds like the wire got hot and burned through to another wire that is hot ni the on position.
    bummer
  3. Pin_Head
    Pin_Head
    14,761
    2,433
    Feb 6, 2002
    OC, CA
    Larry,
    It is easier to run a new wire than to find a short. Make sure that there is nothing connected to the back/white start wire first. Tape a piece of the old wire on to the new one to keep the color code to remind you what it is.
  4. Plowboy
    Plowboy
    798
    3
    Apr 21, 2002
    Problem Found
    Found the problem of the short. This may help someone from burning up a wire harness. THE PROBLEM was caused by the pivot of the emergency brake. When the brake is pulled out, there is a small part of the rod that raises above the framework for the brake. This piece has some sharp edges. The Main Harness passes directly over the sharp edges. I had pulled the speedo out and was moving wires around to see where everything went, when the harness shorted out on that rod. FLAMES EVERYWHERE. pulled the switch wire apart and put the fire out by smothering with CLEAN rag. Note clean, no oil or grease. Need to make some type of cover for the rod and recoat the wires with liquid rubber and rewrap the harness. Will see if I can get a good picture of the area to show exactly what happens.
