4Cruisers
Background:
About four or five years ago I hadn't started my '71 FJ40 for almost twelve years. It had been parked outside of my garage in Southern Nevada and I wanted to drive it into the garage until the start of its resurrection - I finally got around to the build earlier this year. Back then I was able to fire it up and get it into the garage after sitting for so long, which kind of surprised me, but kind of didn't. In 2016 I installed a rebuilt stock carburetor, new fuel filter, new spark plugs, new rotor, new condenser, and new aftermarket coil, but I didn't replace the spark plug wires. I also changed the oil and filter. Because it had the non-US distributor the points I bought from NAPA didn't fit, so I cleaned the contacts on the old points and left them in.
I could never get it to start again, even with a new fully charged battery. I didn't do any more with the FJ40 (had to finish my 2-1/2 year '86 FJ60 build first) until I brought it back to New Mexico recently, and just yesterday started to get it ready to fire up again, or at least try it and troubleshoot as necessary.
Fuel System:
I drained the old fuel (only about a quart was in the tank), temporarily installed an older glass bowl fuel filter with new gasket and filter element, added 2 gallons of fresh fuel to the tank, and cleaned the carburetor fuel inlet and screen so that fuel would get to the fuel bowl. Fuel pump was checked by temporarily disconnecting the inlet pipe and running a short section of fuel hose into a stainless bowl. Once that was done I was able to check the accelerator pump - it works as it should. I still need to readjust the float level, the fuel level is near the top of the sight glass. This morning I plan on installing a swiitched 12V feed to the idle solenoid (per @Coolerman's fantastic installation directions) just to declutter the connections at the coil (+) terminal. I think the fuel system checks out and should be ready to go.
Electrical System:
I started by disconnecting and cleaning a lot of the connections and wire terminals, but still have more to do (see below). I finished the following - ballast resistor, coil, battery terminals and leads, distributor lead (to points), condenser, and ammeter. I also checked to make sure the distributor lead to the points was not shorting to the distributor body - the plastic piece on the outside of the distributor was brittle so it cracked and broke off while tightening the nut, so I fabricated a short nylon spacer to provide the required insulation. I still have to clean the connections at the starter (it cranks fine and the engine turns over freely), the ground cables at the frame/block, the fuses and fuse block, and the ignition switch connectors and leads.
I started to do some resistance and voltage checks. Here's what I've measured so far -
Question - is the 11.19V too low? I'm thinking it should be a bit over 12V. I'll check again after cleaning the rest of the terminals and connectors.
Question - the coil I bought at NAPA indicates "No External Resistor Required", do I need to buy a different coil? Our bypass the external resistor?
I think I'm heading in the right direction. Anything else I should be doing?
Fuel System:
Electrical System:
- Coil (+) to (-) resistance: 3.6 ohm
- External ballast resistor resistance: 1.6 ohm
- Battery (+) to (-) voltage: 12.25V
- Ballast resistor input to battery (-) voltage: 11.19V
- Ballast resistor output to battery (-) voltage: 7.66V
