I was having problems with my ignition switch physically engaging and starting my vehicle. I pulled the old switch and saw that the “female” plastic part was worn/broken on one side. I swapped out the old switch for a new one and the key is working as intended now. That’s the good news.
Bad news: vehicle won’t turn over.
The 4 wires that connect with the switch are Red,White,Yellow and Black, all solid colors. The wires coming from the switch are Black/Blue, Black/Red, Yellow and Black/white. by process of elimination i assumed the “black/blue” wire mated with the solid black wire. When i turn the key to ACC the dash lights come on (radio does not); when i turn the key to “run” the radio comes on and the wipers work; when i turn the key to ”start” it tries to start but won’t turn over. I have an after market EFI that I’ve NEVER had a problem with before on start. I didn’t do anything other than swap out the ignition switch.
so, did I wire it incorrectly or did i mess something else up in the process somehow? Thanks for the anticipated help!!
