I have a later-model steering column with a new from SOR ignition switch, key lock, etc in a 71 FJ40, I'm trying to get the later model switch to work with the old wiring. Any info on what the wires are for on the later model switch? I found what looks like the right code for the 71:
BR (Black/Red Stripe) to AM (accessory?)
BY (Black/Yellow Stripe) to Ignition
BW (Black/White) to Start
On the new column and switch, there are 4 wires:
BW (Black/White Stripe) Is this to Start?
BY (Black/Yellow Stripe) to Ignition?
LR (Blue/Red Stripe) to Accessory?
BR (Black/Red Stripe) to ????
I have OEM connector halves with DIY crimp connectors (I don't want to hack the wiring more than it is) and just need to splice the connector in to the truck.
But I'd like to avoid and fires. I have those special wires that quit working after you let the smoke out so...
Thanks!
Thanks!
