Decided to make my own post because I can’t find the exact problem with a clear solution.
2003 LX 470 Stuck Ignition In acc position
In park. Wheels not locked. Key can be removed. Tried both keys. Tried graphite lubricant and tapped the key lightly with a rubber hammer. That made it worse. Key wouldn’t come out without force.
There are several threads with broken rods causing the ignition to spin but not engage. There are also a few with the lock cylinder being bad and needing a locksmith. And I found one that mentioned a switch assembly.
The part number for the bracket assembly is 45280-60610. Does that include the lock cylinder and switch assembly?
Do I need to take it all apart either way? It’s in my driveway but I was planning on taking it out of town tomorrow.
thanks
thanks
