I have a RHD HJ47 with the 2H engine (12 volt) and I'm trying to locate the Ignition Relay.
The truck won't start unless I disconnect the motor rod from the EDIC. The tach, oil pressure, fuel guage, and hand brake lights also don't work among other things. The engine fuse is good. Reading through the wiring diagrams in the manuals leads me to believe the ignition relay is toast. Can someone point me in the right spot to find this? I know where the starter and glow plug relays are. I've also found the turn signal and wiper relays. My 47 has air conditioning on the passenger side. Is it behind the vents?
Thanks,
Andy
Thanks,
Andy
