Ignition Problems.... She is getting harder to start
Discussion in '60-Series Wagons' started by cruiserhunter, Mar 23, 2004.
  1. cruiserhunter
    cruiserhunter
    417
    1
    Sep 6, 2003
    Austin, TX until 8/04 then Chicago, IL until 6/11
    Everytime I get into my cruiser and try and start her she is taking longer and longer to get started. I pull the choke all the way out and turn the key and i hear the starter trying to get her going, but she won't turn over. After about 3 or 4 good try's she will usually start, but I am waiting for the day when she won't. I put in am STP carb and fuel system cleaner because I had one at the house, but that doesn;t seem to be doing any good. Hope someone has some ideas. Thanks.
    Patrick
  2. BigSur
    BigSur
    1,637
    Feb 11, 2004
    Big D
    Do you pump the pedal at all before you try and start her?
    Try pumping once, then pull the choke and start her up and see what happens.
  3. Romer
    Romer fatherofdaughterofromer Moderator
    10,844
    2,135
    Sep 14, 2003
    Centennial, Colorado
    How long since you have given it a tuneup?
  4. swank60
    swank60
    1,483
    233
    Aug 26, 2002
    One of Four Presidential Flying Saucers
    Is it hard to start after it's warmed up and you've been driving it, or is it cold starting that's a problem?
  5. cruiserhunter
    cruiserhunter
    417
    1
    Sep 6, 2003
    Thanks for the help...
    Bigsur
    pedal is pumped and choke is pulled
    Romer
    Bought her 3 weeks ago and have yet to give her a tune up.. was thinking that new plugs would do the trick and hopefully in the next week I can tune her
    swank60
    if she has been driven she is easier to start ( less time cranking the starter). if it's cold it takes for or five good long crannks to get her started
    Patrick
