This is not my area of expertise by any means here, so if the question seems odd or stupid sorry.
Got my 9/77 FJ with a stock 2F I'm currently trying to finish up a frame off resto on and I'm having some problems with the ignition coil, specificly the ignitor. Had my mechanic buddy over and he bypassed the ignitor and got everything running, but I figured if Toyota thought it was necessary to put in at the factory I should probably have it? I don't even know what the ignitor does, I've heard it regulates the voltage so it doesn't prematurely burn out your points? He used the factory 2F manual and did the tests in the book, supposedly the ignitor is shot?
Spector has got an electronic igninition coversion for $149
Man-a-fre has got a HEI distributor that says you don't need a coil for $375
JT has got some other stuff, Mel's kit $99?
Are there more options I don't know about, or should I try to fix what I got?
Help please, Thanks Matt
