Ignition coil check on my 76 (2 Viewers)
Temecula CA
Hi everyone! Here are my ohm readings from the ignition coil. Is it ok or replace?
Primary 3.1
Secondary 9.93
Its original...
Primary 3.1
Secondary 9.93
Its original...View attachment 2632214
Per the factory service manual, the late coil (used with an igniter) primary coil resistance should be 0.5 - 0.7 Ohms, and the secondary coil resistance should be 11.5 - 15.5 kOhms.
Are you sure you were reading the right band on your ohmmeter?
Oh I'm sure I'm doing it wrong. 😆 I just rechecked and took some
pictures with my settings.
Oh I'm sure I'm doing it wrong. 😆 I just rechecked and took some View attachment 2632369View attachment 2632370pictures with my settings.
Well, your secondary resistance is 10,180 Ohms, so much closer to spec but not quite there. Your primary resistance is still an order of magnitude more than spec, unless I'm not reading the scale on your meter correctly.
The ignition coils that I've seen go bad, usually cracked/broke some of the wire windings due to vibration. Usually when that happens, the resistance numbers are way off, especially in the secondary circuit. So I'm not sure what to think about yours. Has your truck been running with this coil? Did you have any symptoms that made you suspect a bad coil? Bottom line: that one is out of spec, and a new one should not be expensive, so if it was mine I would replace it.
Thanks for the replies. I recently rebuilt the engine and carb. I have the truck running decent(starts and runs good, no loud backfires, chugging). She's runs alittle rich with an occasional pop out the tail pipe and notice the timing bb jumps around at times. I'm sure carb needs better tuning. I only checked the coil mainly because I was curious on its readings.
