Hi everyone! Here are my ohm readings from the ignition coil. Is it ok or replace?
Primary 3.1
Secondary 9.93
Its original...
Primary 3.1
Secondary 9.93
Its original...
Primary 3.1
Secondary 9.93
Its original...View attachment 2632214
Oh I'm sure I'm doing it wrong. I just rechecked and took somePer the factory service manual, the late coil (used with an igniter) primary coil resistance should be 0.5 - 0.7 Ohms, and the secondary coil resistance should be 11.5 - 15.5 kOhms.
Are you sure you were reading the right band on your ohmmeter?
Oh I'm sure I'm doing it wrong. I just rechecked and took some View attachment 2632369View attachment 2632370pictures with my settings.
Thank you!If it is starting & running, the coil is probably okey-dokey. If the coil is damaged/dented or is leaking oil out the top crimp, then it needs replaced.
