I guess I dont know for sure. The light is the only indicator I have. I know the center locks fine because it can go into 4low fine I believe and the front may or may not be locking but it does turn solid.How do you know it doesn’t lock? Besides looking at the flashing light?
I can verify that the light flashes forever which is my only indicator, correct? If its not solid its not locked, correct? Or is it possible that it could be locked and still flashing?You can verify that the rear doesn’t lock up?
Not necessarily true if you dive in to the logic of the f/r ecu. But I will leave that for the other locker threads.The F/R lockers will not lock until the CDL is locked.
The front will not lock until the rear and CDL is locked.
The rear will not lock unless the CDL is locked.
I believe the indicator lamp on the dash is separate from what is actually happening under the truck. Do what was suggested above in order to properly diagnose. I believe there is a section in the FSM that walks through this.
Perfect! Thank you I will try this later.Easy steps to try....
Turn the rear locker on with key in accessory, to determine if there is audible click from rear locker. If no noise, check the wiring and harness at the locker, make sure no corrosion and pins are seated in the harness. If that doesn’t work, remove rear locker actuator and test it on front locker harness. If the locker is inop, it probably has internal issues and needs to be rebuilt or replaced.
Thank you as well.The F/R lockers will not lock until the CDL is locked.
Thank you King.Mine was doing exactly as you describe. It turned out that the springs, shaft, and toothed gear inside the locker were no longer well lubricated. Old grease had gotten dirty over time and dried up. But it could be several things including limit switch, seized actuator rod, motor magnets, etc.
search threads on rebuilding the rear locker by @landtank, @Tools R Us, @RavenTai, @clownmidget, and maybe a few others and there are some great descriptions and pics. Gotta just dive in and start pulling it apart and see what’s up inside.
Yes. In the 96 FSM page SA-101 has a full diagnostic of the diff lock system. Just follow the procedure in the FSM to diagnose.I believe there is a section in the FSM that walks through this.
