I have a questions in regards to the idler pulleys in a 92. I have replace the bearing in the upper, just below the power steering unit, and ordered a new one from Cdan for the one that is located below the A/C unit, and have received it. But when Dan and I talked and deceiced that the one I ordered is the a/c idler pulley, it comes complete with the bracket. When I received it, I realized that it is the same as the upper, with the replacable bearing, so my question is:
Since this unit is a special order and can not return, can I USE the pulley in place of the old one?
I have matched them together and other than the groove being slightly deeper and wider, and it actually bolts right in. I should say it is in and running just fine, is there any reason I shouldn't use it?
Why is Toyota calling this one a A/C idler pulley, when it is located under the power steering unit?
Well I hope this makes sense, and some help in answering is greatly appreciated.
John
WoodyFJ80
John
WoodyFJ80
