thebigredrocker
I know a 55 works, maybe a 60 for your rowdy Canadian engine.
Primary slow - 60I know a 55 works, maybe a 60 for your rowdy Canadian engine.
I put a new 55 slow primary jet in, if thats what is known to work and the 60's slot was buggered up so better not have it break off in the carb anyway.Primary slow - 60
Secondary slow - 80
Primary Main - 120
Secondary Main - 180
Power valve 80.
I am at ~300 ft above sea level
THanks, I did squirt a bunch of carb cleaner around all the shafts and plugs, no change. I will try again.How's the condition of the butterfly shaft? Badly worn can suck air through there and make tuning difficult.
X2Badly worn can suck air through there and make tuning difficult.
No, I had to go at it passage-by-passage with cleaner, air and dust-free Kimwipes. 3x now I dont know if other Canucks found if but I couldnt get Berrymans or Gunk locally or delivered. Not that surprising...you guys get wood stain we cant get due to the chemicals (try getting TWP!)Dumb question: did you submerse soak your carb in carb cleaner solution (like Berrymans or Gunk Carb cleaner)?
Hi, thanks for the reply. Do you do that with the vacuum on the distributor, or disconnected?I’m old school, advance the timing until it idles, I never fully trust a timing light, tune by ear is the old way, advance until it pings, and back off a couple degrees!!
Fuel weeping off the end of the throttle shaft is normal. There is no seal on the shaft. When the engine is running, fuel is sprayed at the shaft, but manifold vacuum prevents the fuel from wicking out to the end of the shaft. After shutdown, the residual fuel is drawn out by capillary action, possibly getting a drop on the end of the shaft.
This.how it acts when you twist the distributor like Whitey mentioned.
Hahaha, you might be thinking of another of my threads....I now use 3 timing lights to check each other!This.
There was another thread here recently where a timing light setting caused all sorts of problems. At least retard it a bit and eliminate timing issues first.
It doesnt change if I cap off/Pinch off the valve cover, brake booster, distributor advance or vacuum gauge (those are the only 3 vacuum uses and only 3 taps into the intake) When its idling at ~725 with the choke on the distributor shows 11 degrees advance (on 2 different timing lights) with or without the vacuum attached to the dizzy.I wonder if you have a lack of vacuum. Did you have your manifolds sanded flat? If not, I'd do that before mailing off the carb. Then I'd use a Fel-Pro manifold gasket. @Mark W and FJ40Jim have both said they have faith in Fel-Pro manifold gaskets.
I think a video or video's of your engine running, behavior with carb choked and un-choked, how it acts when you twist the distributor like Whitey mentioned.
I'd be curious how it runs if you just temporarily cap off the vac advance fittings.
Just curious you said you have a new cam installed have you properly run this in? If not i would be doing this before tinkering with idle much more
