Actually in light of your discovery I think you should change gears and remove the security system. You will need to literally trace the wires back to where they intercept the harness, cut them out or remove the connectors. then either reconnect the harness to itself or if the harness was cut, solder in wires to reconnect the factory wires. Use heat shrink, take tons of photos.
There is a fair chance this alarm system is cutting the spark signal as it’s form of anti theft immobilization.
