Idle Solenoid?
Discussion in '40- & 55-Series Tech' started by xumFJ40, Mar 19, 2004.
  1. xumFJ40
    xumFJ40
    376
    2
    May 9, 2003
    Tex..as...Ohhhh...Texas!!!
    I am trying to determine if my idle solenoid is working or not.
    How do you test the actual solenoid? If I put a multi-meter between the wire that connects to the idle solenoid and the negative terminal of the battery should I get 12V with the key on?
    As it stands I get .3V when I do this, so I am thinking that it is another problem....any advice?
    Thanks,
  2. jwest
    jwest
    688
    1
    Mar 12, 2004
    With key on engine off, if you disconnect the solenoid, you should hear it click off.
  3. Pin_Head
    Pin_Head
    14,580
    2,210
    Feb 6, 2002
    OC, CA
    The function test of listening for it clicking is a good indication of correct operation, but 0.3 V at the connection can't be good. Either there is a high impedance connection upstream of the solenoid or the solenoid is shorted.
  4. xumFJ40
    xumFJ40
    376
    2
    May 9, 2003
    Pin_head,
    Ok, I know that this sounds weird, but the truck idles. However, I don't hear the click, and as I stated before the voltage is .3 between the lead that connects to the solenoid w/the neg of the multi-meter attached to the neg term of the bat....
    I adjusted some idle settings on the carb this weekend.
    I guess if it runs I shouldn't worry about it...
  5. Pin_Head
    Pin_Head
    14,580
    2,210
    Feb 6, 2002
    OC, CA
    If it ain't broke, don't fix it.
    .3 V is strange because of the voltage drop across two resistors in series. The resistance of the solenoid is about 25 ohms, while the wire leading to it should be less than 1 ohm. It should read about 12V. Either the solenoid resistance is too low (shorted) or the resistance of the fed circuit is too high (bad/corroded connection).
  6. Rocky_LC
    Rocky_LC
    1,553
    49
    Sep 16, 2002
    Tucson, AZ
    If your PO was anything like mine, every wire on your truck should have a crappy splice in it.
    If you can easily access the wire, you should be able to jumper +12V from the battery direct to the solenoid, and hear it "click" to test the function.
    I wouldn't cut into a good wire for this test, though.
    I can't believe the problem is in the solenoid, since a short on 12V would pull alot of current.
    I looked at my wiring diagram, but couldn't tell if that curcuit is fused (it should be).
    Rocky
