I have a 1994 FJ80 with a rough idle. Rough enough that it dies if you take your foot off of it.
It started when I took apart the air cleaner when it was running. I eyeballed the aircleaner and as it sat running just fine, it got real rough and died. I put the air cleaner back together and started it and it ran rough again and died. It has been doing this ever since.
I just did the paper clip across TE1 and E1 trick to pull codes five minutes ago. The check engine light didn't give me codes but instead flashed constantly. I waited forever for it to stop and it did not.
I read elsewhere on this board about dummy codes. I thought that this was what I was seeing so I pulled the EFI and dome light fuse for at least five minutes. Put them back in and tried again and still constant flashing.
As I type this, I have both fuses out and the battery disconnected. I am going to leave it like that until I hopefully get some advice.
Anyone have any ideas?
Thanks in advance.
Thanks in advance.
