idle adjustment / Idle mix screws 77 FJ40
Berthoud Colorado
Website
www.w2m.com
Ok,
got my timing advanced..truck runs great.
However, the idle is too high.
The idle adjustment screw will only let me raise the idle...so, I raised it a little more so the mix screw did nothing...
Im confused anyone else....???
Take to a shop that has the proper tunning equipment or what..
It is possible that your fast idle screw is in too far, so letting off your idle speed screw doesn't work.
This mechanism...
is this guy pulling off your idle?
Not sure what your talking about...
PabloCruise said:
Razor,
What do you mean "too high"?
Is your throttle positioning solenoid kicking pulling off?
If not, it will keep your idle high, mine is ~1150 RPM
Do you know what I'm talking about?
If the screw is missing it sounds like someone tried to fix the problem by removing it. Is the choke open allthe way? The choke also sets a high idle cam that is controled by the verticle link rod in the picture. make sure that this linkage is not stuck or improperly installed so that the high idle cam is always engaged. The choke high idle speed is adjusted by the screw with the pink arrow.
I sold my 40 with my stock carb so don't have it here for reference.
I recall what Pin-Head referenced. There are levers (cams?) in the linkage which bottom out on screws. The screws adjust when/how they bottom out. If these are set improperly, you could be bottoming out with the choke or accelerator still partially engaged thus increasing your idle speed.
Then again, maybe I am just an idiot. But this is what I recell when working on my Aisin before.
AndrewT
Razor,
Is your '77 a federal spec? Cali? High altitude?
I just checked the SOR page on carbs. THe '77s are a little different than my '78.
Do you have an emissions manual? They will tell you how to adjust your carb...
Or, Andrew posted this on my ABV thread: http://tinyurl.com/6hf58
It is from Autozone.com - you will have to register to use it. I believe registration is free.
Here is a pic of what MAY be your carb, from SOR:
PabloCruise said:
so what are you idling at?
So what is the idle speed?
It is easy to see why the throttle positioner idle speed control is gone. Without the smog computer it will always be stuck on. The other idle adjusting screws are the choke idle speed adjustment shown with the pink arrow in the first picture facing the valve cover. The main idle speed adjustment is hard to see and it is located in the cabr base casting on the drivers side of the primary throttle shaft. It is hiding behind the bottom spring of the last picture. Try adjusting the main idle screw with the choke open.
Rick,
I also have a 77. Did you try adjusting the mixture screw per the FAQ. My idle was up around 1200 rpm and then I did the full adjustment per the FAQ and its down to 600 rpm. I couldn't find the 2nd screw either. Just adjusted the idle and the mixture.
Pin_heads directions are probably good. He picked my bearing problem correctly.
Ken
