I have waited too long to fix the two battery system the previous owner had installed in the system, and now I am up against a trip deadline and kicking myself.
Here's what the setup is/was:
So, now I am up against a deadline.
Options I see:
I can't get in to any local shops in time for the trip (idiot!) so, left to my own devices and once again coming to the community for advice.
Thanks!
- 1 main, lead battery in normal location to start vehicle etc
- 1 AGM battery on passenger side of engine compartment, in the back toward the windshield
- cables directly connecting the positives of the two batteries, no fuses
- those cables went under some pinch points where I thought with another rattling/jolting, might pierce the cable insulation and cause a short
- winch and ARB compressor tied to second battery
- AGM battery was dead when I got it
Options I see:
- install a proper 2 battery system with either a solenoid or some other monitoring device that ensures batteries don't drain each other, including fuses between to avoid any major electrical shorts (if so, what, and could I order it and it get here and I install it in say, next 2 weeks)
- replace AGM battery and reconnect everything as it was (seems unwise, but again, I don't know enough)
- find longer cables to directly connect winch and compressor to main battery, remove 2nd battery (not anticipating doing crazy offroading, kids will be with me, probably have 1 or 2 excursions on light packed roads, no crazy rock climbing, etc.) -- or just route the cables, and only connect if I need to
Thanks!
