Hey, Mud world! My daughter and her husband really want a used Subaru Outback. They can either choose from a version that has known Timing belt and Head Gasket issues, or known issues with excessive oil consumption, leading to downstream issues with cats and sensors and the like.
It's easy enough to find something with a replaced timing belt and HG, but these are the pre-2013 vehicles. Higher milage typically. How do you identify an oil burner when 1 in 50 vehicles were diagnosed with this issue? It's 1 qt of oil every 1k to 1.2k miles, which is standard for an old Land Cruiser, but for a Subaru with 70k to 110k miles it should be unacceptable.
Check the exhaust tip: I think most of it is caught in the catalytic converter(s).
Other suggestions?
Edit: The notorious problem is caused by poorly fitted piston rings. It's a mfg defect with a class action lawsuit against Subaru.
Other suggestions?
