identifying a rear full floater
Discussion in '40- & 55-Series Tech' started by Junk, Aug 7, 2005.
  1. Junk
    Junk
    6,177
    31
    Dec 13, 2002
    buggerville nj
    The Canuck spec 77 fj45 I have has what seems to be a full floater but not the normal 45 FF. This one has the ebrake on the axle instead of the tcase. What's the best way for me to try to identify exactly which axle this is?
  2. Texican
    Texican s-Moderator
    5,964
    Media:
    175
    Albums:
    7
    321
    Dec 17, 2002
    Bonham Tx.
    WTF do you mean "seems to be a FF?"
    It's either a FF or it ain't, surely you know how to tell the difference..........if not,
    STOOPID!!! :D :D
  3. cruiseroutfit
    cruiseroutfit Supporting Vendor Moderator
    8,821
    6,582
    Jan 9, 2003
    Utah
    Easiest way is looking at the axle flange & lug nuts... If it has the hub assembly protruding through (with an additional 6 nuts & studs), in addition to the 6 lug nuts set back in, then it is a FF.
    If the axle end is flush with the rim and no extra nuts or studs are present (just the 6 lug nuts) then it is SF. The only dilema, when people run center caps...
    Next, does it have a diff cover? 79' & later FF's didn't have a diff cover on the rear axle, not sure about the earlier ones as I have never seen an early FF firsthand.
    Hope that helps... :D
    Oh yeah, take a pic! :D
  4. StanCruiserMan
    StanCruiserMan
    121
    1
    Jul 14, 2005
    Let's see some pics!
    Here is my 81. It has a split case and still has the ebrake on the case. I have heard of some 1984 40 series having it mounted to the axle.
  5. lowenbrau
    lowenbrau SILVER Star
    3,698
    130
    Jan 22, 2003
    near Calgary AB
    I'm guessing that it's the factory axle assembly that the PO modified to accept a p-brake when he put the NV4500 in. It had an e-locker in it at one time as well so clearly the guy knew how to mix and match parts.
  6. HawkDriver
    HawkDriver
    3,308
    Media:
    66
    Albums:
    5
    100
    Feb 1, 2002
    No. Ogden, Utah
    http://www.cs.odu.edu/~glaves/chris/axle/
    Jeez man what happened to the rest of the internet? JK
    If it looks like this it's a full floater, because the axle can simply be unbolted and slid out with the wheel and tire still sitting on the ground. You don't even have to take off the diff cover to take out any clips. They are sweet. Snap an axle and easily replace it quick. ;)
  7. Junk
    Junk
    6,177
    31
    Dec 13, 2002
    buggerville nj
    Go stick your head back up Nolen's ass Texican. Yeah, it's a FF, what I meant was that it seems to not be from the 45. :doh:
  8. Junk
    Junk
    6,177
    31
    Dec 13, 2002
    buggerville nj
    That makes sense except the same owner also rigged the F engine to recirculate without the oil filter and a lot of other dumb things. So I'm thinking he was paying someone else to do the work.
  9. Texican
    Texican s-Moderator
    5,964
    Media:
    175
    Albums:
    7
    321
    Dec 17, 2002
    Bonham Tx.
    SAY WHAT YOU MEAN THEN YA' DUMB ASS YANKEE :D :D
    /QUOTE]
    /QUOTE]
  10. wesintl
    wesintl
    4,522
    Media:
    1
    Albums:
    1
    35
    Mar 14, 2003
    Between Here and There
    and what about the work boot body mounts :confused: :D
  11. Trollhole
    Trollhole THC Supporting Vendor Moderator
    20,939
    Media:
    79
    Albums:
    4
    3,018
    Mar 6, 2005
    Mauldin, SC
    SO if you snap an axle it's easy to replace. So how easy is it to get the piece you snapped off out?
    :confused:
    Just curious.
  12. honk
    honk
    3,413
    Media:
    10
    372
    Nov 14, 2004
    PNW
    Jeez, five non-readers who didn't understand the question.
    Could it be an 80 series axle housing?
    Never mind that, a better question is 'how easy is it to find a replacement axle?'
  13. HawkDriver
    HawkDriver
    3,308
    Media:
    66
    Albums:
    5
    100
    Feb 1, 2002
    No. Ogden, Utah
    Yeah I get it now :flipoff2:
    Prob depends on the axle used. A BFM (Big Fawking Magnet), telescopic preferrably, if you're lucky and had a clean break, otherwise you're pulling the cover to push it out. Better bring empty containers for all that oil.
  14. Nick the Carpenter
    Nick the Carpenter
    198
    May 16, 2005
    Rockingham: Western Australia
    use a welder to stick the wire to the rod .Turn power off then pull the axel.If stuck in bush find a fence.
  15. lowenbrau
    3,698
    130
    Jan 22, 2003
    near Calgary AB
    Toyota floaters have no cover.
    If the shaft breaks anywhere but right at the splines, you *have* to get it out through the tube.
  16. HawkDriver
    HawkDriver
    3,308
    Media:
    66
    Albums:
    5
    100
    Feb 1, 2002
    No. Ogden, Utah
    Aha, and another way to ID. Thanks, I don't think I've ever seen one. I was making a generalization. ;)
  17. bcon
    bcon
    98
    1
    Apr 1, 2005
    Northern California
    Just a thought, but my hj60 and bj73 both have ebrakes on the rear housing rather than the tcase. On the rack, the only FF housings with ebrakes on them are from FJ60, HJ60, HJ73, and HJ75. Ill look but i think the 78/79 are the same. We had a 40 with 70 series running gear similar to what youre describing. Just a thought. Maybe just measure a few things like perches and stuff? Just an idea, Good Luck.
