Ideas for hood scoops? (I figured it out but there’s a lot of good info for other people)
Cowl induction type. All steel welded in
Thats a redneck hood..no offense.
What height filter element and filter base/top are you currently using? Do a severe drop base air filter. There are different ones but you should probably be able find them to give you the clearance, if the holley sniper set up uses a 4150 style diameter? Run a wide diameter filter housing with shorter element for more clearance as well and then run an element filter top if needing the extra airflow (I doubt it would be necessary with a mild 350).
I had seen someone on this forum graft a 2004 4runner or Hilux hood scoop on an 80 hood, beautiful job. I could not find the post. At least 3 to 4 years ago.
If you liked the old style ’68-69 Camaro cowl hoods, then this is pretty damn cool.
I’d like to see that rear lip overhang like the Camaro, but armchair QB statement, 100%
Beauty is subjective - I like this over alot hood mods or rando bolt-on gear others do :meh:
It's definitely a little different
I get it, they try to put a cowl hood on my 73 RX-3 back in the 80s when most ppl mistaken it as a MUSTANG.
.go figure
Hi
Hi, that scoop looks good on your 80.
How did you mount it?
which model year and type is it?
There are a few different ones on the market.
Thanks, Stephan
I know that scoop is from the 04-05 STi.
And 8 years later its still trucking on. Off a 78 series grafted in.
I debated doing a 4runner sport graft but the Scoobie was a great fit when I was planning a top mounted IC'er...... yes 04' STI model IIRC. it for sure isn't for everyone but does really keep temps down in tandem with the vents.
The hood risers are nice because it's easy to switch back to stock.
my redneck shaker hood:
20160906_181901-jpg.1318028
20160906_181915-jpg.1318030
You just have to put up with people asking if you hood is broken or not latched 🤷‍♂️
