I'm running the Icon Progressives and really like the ride quality (also running 2.5 RR CDCV), but the ride height is a bit low with my weight. I'm 3,700 lbs front and 4,400 lbs rear. I'm trying to compare the Icon's against the OME's, however IVD doesn't publish a spring rate for their springs. Further complicating the decision is that OME shows the 2724 rating at a 3/4" lift.
So... is there any MUD knowledge of what type of gain I should expect if I were to change to the 2724s? Or should I go to the 2725s? At some point the big boy will have another 200lbs of rear bumper and possibly the aux tank.
I know that XO is running the IVD springs with a similarly laden vehicle. They have 33s on theirs and have a rear wheel well gap similar to mine but appear to have leveled the vehicle by lowering the front coilovers. I'd rather keep the front height if I could.
Or what about 30mm coil spacers? Are such available from the 200? I'm not bottoming out the suspension so the rate is probably OK (at 4,400 lbs at least), I just want to increase the rear height an inch or so.
