I want to rebuild my starter sedonoid (1 Viewer)
I have an FJ80 with a 2KW starter. I want to rebuild my starter solenoid. Is there a procedure that I can download from somewhere? Are there any special tools that I need to rebuild the solenoid?
I'm sure there's a writeup somewhere on here, but I would make one suggestion.
A lot of the guys who do this replace only the contacts. However, usually the plunger contact point also wears, and I would recommend replacing it as well.
It's really a very simple procedure and if you're good at taking things apart and then putting them back together, you could do this without any guide.
Don't forget to clean things out when you've got it all apart.
Thanks for the info. I am looking at replacing the contacts as-well-as the plunger. I'll check around the site for instructions. Have a good one!
