I v problem n i need support of any who can do please 🙏
Yemen
I have a problem herewith the my audio system of my land cruiser 2008 Radio system stopped n doesn't work at all
You are probably going to have to provide more detail as to what “stopped, not working at all” means. From your picture, the Screen appears to be working. No audio? Can’t change inputs? can’t receive radio stations?
NO the pic is not for now
.now it the radio doesn't work at all .no power . nothing appear on the screen , just a message of check the system
Also the Computer check Report shows the attached pics in case it is relevant
I would be checking fuses. That’s a lot of ECUs to have lost communication. I doubt it’s the stereo that is broken. Looks like you have an electrical problem.
Maybe even begin checking battery voltage, tightness of both battery terminals, condition of wiring (make sure they haven't been eaten by a rodent), and the fuses as mentioned above (there are three fuse boxes...).
Do u think so dear .as the electrician says it's not
n was talking about an information software and memory but he hasn't.
I appreciate your feedback just i wanna know what is the possible fault
Most probable is a fuse as pointed out.
Second most probable is battery or battery connections as pointed out.
Third most probable is water intrusion and some shorts in a connector or two.
Fourth most probable is that the capacitor(s) in the amp or source units have failed and there is a failure in the amp (probably)
Wow. Those are some interesting codes. Did anything happen prior to the radio failure? Were you driving the truck regularly? What has the weather been like recently? Any recent service done on the truck?
My first inclination would be rodent damage or water intrusion.
Everything was normal ,i just remember that i choose on the screen the default settings and erasing the personal data.so does that mean anything to the issue
