I think i might be developing a rod knock. Odd think is i have always had good oil pressure and it has not been overheated. but so goes life. Right now it is nothing bad just a strange "rhythmic" noise. I am going to have Beno take a look at it and see what he thinks. But if it is the bottom end what are my options with rebuilding? If it is crank/rods and the boors look good it possible to just pull the motor and head and do new crank and rod bearings? I was all ready looking to do a head rebuild in the future so that will be done regardless. But the bottom end was not on my radar. I would imagine the big expense becomes OEM pistons/rings. Obviously if the rod or crank spun a bearing and is scored it is toast. But any chance it can have a little knocking and be repaired with just bearings and after having the rod inspected by a machine shop?
PS i have my fingers crossed on this but i am not hopefull. the noise is not load but i have a bad feeling. Right now it is quiet enough that you cant hear it driving. The road noise at even at light throttle covers it up at about 20 MPH.
Edit: Figured it out. Holly crap and i happy it is not the bottom end. It is a exhaust leak which i kind of thought it might be. But last night when i first noticed it in the parking deck for work i crawled around the right side and the exhaust. The sound was much quieter. So i figured it was not a exhaust leak. Where else do we have exhaust? The F&$@ing EGR tube! Today when i had time to really look at it the sound really sounded more like the top end and back by cylinder 6. So crawled over there. and the noise is all around the EGR tube. Also the tube has a lot of play in it like it is loose. Who knows? Cool thing is i was getting ready to do a head gasket mostly to fix worn valve guide seals. So while the head is out i will just Pull the EGR tube and put a block off plate on there.
Thanks for everyones advice and help.
