i think i figured out why the power steering was making noises
North Cadillac
what do yall think? I noticed this today while changing my oil. One thing that has me thinking is i've seemed to notice more folks speaking of leaks and power steering pump rebuilds AFTER they flush their fluid. Mine just developed this leaking AFTER the flush. hmmmm...
Did you do a flush or just a drain and refill? I was debating on flushing, but based on this and other threads, I think I will leave well enough alone.
I did the flush. Put the front on jack stands, unhooked return line, turned wheels side to side while adding new fluid until fluid looked new.........BUT, the fluid looked horrible before, so i don't know what to say.
I did the drain and refill with mechanical pumping (per RT's great idea)
I can't imagine why that would cause leaks.
However, it is very possible that putting in clean fluid would dislodge a bunch of crud that was previously clogging leaks up.
Guess the result is the same, however, I would not go a step further and say that I wouldn't put in clean fluid because of the fear of revealing preeexisting leaks -if that's what it is-...
might as well find out and repair in the garage rather than in the middle of the rubicon...
1 - Remove old brown fluid with no detergents
2 – Add new red fluid with fresh detergents
3 – Watch P/S system leak
Been there
Done that
And bought the rebuild kit and new low pressure hoses
4 – Watch high pressure hose leak 2 months later
5 – Buy new high pressure hose and replace and hope the box does not leak
I just turned 160,000. I did the flush around 152,000. developed a leaky resevoir cap shortly after. Replaced the cap a week or two ago (thanks cdan). I have been noticing the groan (i can actually feel it vibrate at times right up through the steering column) for about 3 weeks. :o
I am kind of hopeing that it is residual fluid from my leaking resivoir cap. But it sure looks like alot! I'll clean the box and stuff up, wipe it down and see if it's leaking.
so, Phil and MoJ, you tryin' to tell us we should never replace the PS fluid????
landtoy80 said:
I did my flush on Mosquito Pass in CO, all the way over the pass.
I filled it 20 miles later when I found a store that sole ATF.
could one take 1/2 qt or so from the Trans in a pinch?
Well, i cleaned off the box and drove it around for a day. THis morning there is a small (about the size of a 50cent piece) puddle of red fluid on the driveway right under the powersteering box. I can't tell exactly where it's leaking though. Seems to be all over it.
For those who have tackled rebuilding the box, is it tough? I haven't dug into the FSM to check it out yet. I'll PM Cdan with a request for rebuild kit, but, off the cuff anyone remember price on such a kit?
Just as another data point, I simply siphoned with my vacuum gauge/vacuum tester about 2 ounces into the container you can use for bleeding brakes ( I dont like vacuum bleeding brakes, btw), then filled with fresh, then repeated every other day til I had an entire quart of fresh fluid in the system. That was last year about 12K ago, so far no leaks whatsoever and yet the fluid is fresh and red and purty! HTH.
I can't imagine why a manual pump job would be any worse, but yes, if in doubt this would be a safer way to go. Uses more fluid to get it done though.
dd113 said:
I change 80, 60, 62, 40 PS fluid about every day with almost no issues. Use redline syn ATF. Change it at least once a year.
how do you do the change?
I just did mine like 500 miles ago, so far so good with fingers crossed.
I wonder what you will find that is leaking.
Good Luck
steven
