I Suck At Finishing Drywall
If you want to duplicate an orange peel the machine is usually the key to a quality and consistent finish. You can rent the machines and a good machine makes the project almost fun. Spraying an orange peel texture was the most enjoyable part of finishing my house.
There is usually a weight that you drop into the mud before adding to the hopper and based on how fast it falls you adjust the water.
It is pretty common to add quite a bit of water to the mud to get it right.
I would not really recommend the hand-held hoppers unless you are a professional bodybuilder. Those things get heavy very quickly and if you can't move fast enough then your pattern won't be consistent.
The self-contained big monster is the way to go. :beer:
Guys thanks again for all the advice. The only potential problem I see with the machinery is that in some areas I'm doing, the rest of the room is finished with carpeting, furnishings, fixtures, etc. That's why I was thinking a manual method, although slower, would be better. Is there any way to duplicate the orange peel manually? Thanks. :cheers:
