- Joined
- Aug 13, 2007
- Threads
- 22
- Messages
- 125
- Location
- Maple Ridge BC
- Website
- chrisbromptonphotography.com
As some may know, I'm putting Keith's (Diesel42) Turbo kit on my BJ60. I recently pressure washed my engine to determine my oil leak locations.
I noticed that oil was leaking out of the breather cover bolts and nuts above the oil cooler. No problem cheap cork gasket and I have to remove the exhaust manifold anyways.
Yesterday I noticed oil leaking directly above the water pump. Not a ton but enough that the top of the water pump was slightly wet to the touch but not pooling. I assume this is the head gasket leaking.
I have had no motor problems and only 207K Km. The engine does run slightly hot but I suspect that is due to the original 3-core Rad with 2 pinhole leaks on the top tank. This is getting re-cored.
Do I get into this head? Replace the gasket and chance seeing cracked precups, warped or cracked head? Should I just open it up, replace the gasket and close it? Or just leave it...
I don't really have the know-how to get into something like this. And I don't have the money to fork out $85/hr in labor. I do have the manual and a neighbor who's an ex mechanic with all the tools I would need.
Anyone got any advice? experience with this?
Thanks
Thanks
