I need a 2F cylinder Head 1978
Spokane, Wa
Looking for a 1978 2F Head. Casting 61031. May also go for a complete engine. Trying to stay under $200
Thanks,
Brittain
I may be able to. Any way you could check the casting number on the head for me?
It should be stamped on the top of the head itself. It's up front and next to the valve cover. 5 digits long and starts with a 6. I'm going to end up milling the head to get close to 9:1 compression instead of the stock 7.8:1.
Thanks!
Brittain
here's a pic of the head number
Head number is the 61040 number, this is from a newer head. It's right next to piston #2.
Brittain
Thanks,
I need to see if that will work with a 2F block.
I'll let you know soon.
Brittain
Looks like it does work, however I'll have to run premium. (Mike) Myquesttoyota has a 2f head that won't require premium available. If his head check out (no cracks) then I'll go that route, if not I'll be all for your engine. It wouldn't have been an issue if I hadn't already rebuilt the bottom end while the head was being cleaned.
Brittain
