I know my shocks are toast-"rub" in front end
I know that my shocks are done for and need replacing. I notice a "rub" sound from my front end when the wheel is turned while I am changing from one surface to another. Example - wheel turned and going from steep driveway to street. It does not happen (I believe) while going up/down quickly and traveling straight. The sound happens only when I "impact" the elevation change and one quick rubbing sound (for lack of a better description). Is it just shocks / springs / shackles or something more sinister. The steering never feels anything odd, all smooth. The tires track straight and the brakes perform in a straight line (unless one is wet) Thanks
PS Does not sound like a tir rub -- metallic sounding / chirp--poor description I know...Thanks
Naples/Big Pine Key, Fl
I've never heard a shock make a "rub" sound, possible I guess, more likely your tire(s) are making contact somewhere: fender, spring......
Change your tires lately, suspension sagging more???? I'd look here first.
McCall, ID
Yeah, I'd vote for tires rubbing due to sagging springs. Or, you have wrong backspace on your rims. Or, a combination.
Jonathan_Ferguson
★ is in the wrong locale
Glen Waverley, Victoria, Australia
Website
Jonathan-Ferguson.tk
It's most likely that your Dampers are bent. - It's becouse of the way in winch they're mounted and there's excessive forward and backwards movement. :-[
The better type of mounting is like on most Light Commercial Vehicles, Where one sides Damper goes forward and the other sides rearward. - I guess a Tacoma would use this system. :cheers:
mwalls54
Cruiser Nutjob
Roanoke, VA
i had the exact same problem on my 74 and i replaced the shocks and i havn't noticed it yet. so i think that was my problem.
