I know, I know, use the SEARCH, but...
I'm going to take the plunge (limited mechanical experience but have access to a DIY shop with all the tools - free!) and do the birfield maintenance.
First thing I did was search your files and all I got was bits and peices of anything with birf in it. Not really happy with the results.
I need an honest, no sh.. , detailed explanation (tools required, supplies, with pictures if possible, etc.) of how to acomplish this task.
This is for a '91. It has close to 200K and honestly don't know if its ever been done.
If someone can either post a link or email me at:
covertmate@hotmail.com
I would really appreciate it folks.
Thanks in advance.
-C
Landtank,
thanks for the help. In your oppinion, do you think using the FSM in adition to the links you directed me to would make the job go easier?
I still haven't purchased my FSM and was wondering if its worth buying it.
Thanks again.
-C
if you plan on keeping your 80 for any length of time the FSM is a good investment, If you have a Toyota (as opposed to LX450) contact Cruiser dan about getting the FSM,
-C if you can hold off a couple of weeks, I am assembling a FAQ on how to do this. Unfortunately I am working all the time right now so no time...
I would buy the FSM for sure. IT gives you torque settings and good diagrams.
You could probably do it without it if you use all three tech links together, plus search and printout the many threads with snippets of info.
you may want to do your brake pads at the same time, and you might want to check and see if you rotors need replacing since this is a perfect time.
tlcrook, with that writeup and the fsm, you should be in great shape. You will get cold feet etc, but check back here if you have questions. There's usually someone around to answer questions.
Good deal on trying SEARCH first - appreciate the try.
Checked your profile, but location is blank. If you give us a general vicinity, someone may be near by. I'm in NJ and have frequently told folks I would make myself available to assist. We're here to help each other out best we can. I never turned a wrench till I got my beater truck. Still don't know much, but have learned a bunch and am willing to tackle a lot of things. Whenever possible though, I always try to get somone more knowledgeable around me, even if by email, in case I need help.
Good luck, take pics, and let us know if you need help.
Landtank, Raven Tai, et al,
Thanks guys for the great info.
If anyone comes accross Cruiser Dan, I'm interested in acquiring the FSM for a '91.
I have to figure out how to update my profile, but in the mean time, I'm in Midcoast Maine, and anyone around the area (NH, MA, VT), I'd be looking forward to learn form your mechanical abilities, experiences working on these vehicles, etc.
Thanks,
-C
[quote author=tlcrookie link=board=2;threadid=12677;start=msg116574#msg116574 date=1078635665]
[/quote]
CruiserDan is another user on this forum and you can easily access him and order the book by sending him a Private Message (PM). You can find his username on the Member List and a link to PM him there. Good Luck. My FSM has already saved me hundreds of dollars in repairs, it just walks you through how to do everything with pictures, tools required, and torque specs.
Thanks,
-C
[/quote]
I'm in CT and am planning on doing my '91 in the next 2 weeks, whenever I get the time --
-- how far are you from Stamford?
eric
tlc -- there are a number of guys in ME from this forum. Look on the member map. Not everyone puts their location on this map, but I see several pins up there.
As Junk said, the forum is a great resource if you run into difficulties or have questions when you're knee deep in grease. I can attest to that after having done something really stupid when I did my own front axle--the guys here were able to come up with several solutions in only minutes.
I would recommend the FSM in addition to the how-to articles mentioned. The diagrams alone make it easier to visualize what they're talking about, and the torque specs are all right there. You'll be saving many times the cost of the manuals by doing the birfs alone! Some of us also use the savings aspect to hold back the nasty comments and blank stares that our wives give us for buying tools :D
Tom
[quote author=tlcrookie link=board=2;threadid=12677;start=msg116490#msg116490 date=1078624044]
[/quote]
Doubt if they have ever been done. Most owners of LC's use them to go to the mall and would never think to redo the birfields, since that is not part of any normal LC routine maintance process published by Toyota. Just wondering are your steering knuckles leaking or are your birfields making noise? I'm not saying you should not do the birfields I'm just wondering if you are having any problems with them at 200K miles?
[quote author=Pitbull link=board=2;threadid=12677;start=msg116704#msg116704 date=1078674821]
[/quote]
Sorry guys, I'm working on my Landcruiser PhD and this is part of my paper. This is my second try at getting a PhD, the first one was based on the flat earth theory, I'm hoping for better results this time. :)
Keep your head up Pitbull. They may say your elevator stops a little short of the top floor now, but even Einstein had a learning disability, and many of his theories were decades, if not a century ahead of his time. At least you can always say you took one for the team.
:cheers:
R2
