Wow, the internals do look brand new. My '97 w/ 104K didn't look that good when I changed out the valve cover gasket.
I noted that I had a VC gasket leak before... and when I went to take the rear cover bolts loose I found they were finger tight at best. I suspect a lot of them leak when they could just be retorqued.Wow, the internals do look brand new. My '97 w/ 104K didn't look that good when I changed out the valve cover gasket.
The old HG is most definitely fubar, however is it just me or are some of the rings on the new one not perfectly circular either?
I'm so tired of this thing......................
One extremely long cheater bar and a broken 14mm snapon socket later...
I'd imagine they have jobs and an extra car to get around.Some people take months to get this far...
Few questions, the head is sitting on a 4x4 ontop of the block giving me easier access to the last couple of wires for the harness.
1. How do I get the two huge blocks disconnected for the tranny, I don't see a tab.
2. How does the wire to the starter disconnect, I see no tab.
3. Where do the two wires that run on top of the transmission disconnect and what are they?
I've got a total of about 15 hours in it about now, but I'm not taking my time.
I think I'm stuck where I am for now without help... I dunno, I'll look the situation over. I know for a fact I can lift the head/intake together by myself but I'm screwed with the remaining wires that run though the manifold. I can't really get in to the ECU area to feed it out and I've read that it is very difficult to get the harness through the mani that way.
I'd sat the head ontop of the block on a piece of wood hoping it'd give me extra room to unplug everything but it appears not everything can be easily unplugged for whatever reason.
I think it is just that they have a hard time mfg it round.I don't know the magic behind it, but that is on purpose
Damn, thank you for the pictures.Take the harness from under the drivers side dash. And snake it thru the intake.
I think it took about half a hour to get it out. Not very difficult.
I dunno, I'll look the situation over. I know for a fact I can lift the head/intake together by myself but I'm screwed with the remaining wires that run though the manifold. I can't really get in to the ECU area to feed it out and I've read that it is very difficult to get the harness through the mani that way..
