Hey guys. I pulled my '77 FJ40 out of storage a few weeks ago and had an issue with my starter that I would sometimes just get a "click." My Tacoma has done this for the last 2 years and the dealer cannot diagnose it because it doesn't happen when it's at the dealer. Anyway, I'm used to just turning my key a few times until the starter finally engages so that's what I have been doing and after a few tries, it has started right up. Fast forward to last weekend and I was on my way to a car show and I noticed my brake pedal getting lower and lower. I turned around to limp home and by the time I got here, I had ZERO brakes. Reservoir full and no leaks, so I assumed the master cylinder. I had just replaced my old one with a cheapie from Rock Auto until I had time to rebuild the OEM. While waiting for the rebuild parts, the truck decided to puke about a cup of gear oil onto the driveway, I didn't take the protective cover off, but it appears to be coming from the back of the transaxle. I received my parts today to rebuild my master, I got that completed and dropped one of the nuts. I could hear that it didn't hit the driveway, but after searching for nearly an hour, I can't find that effing think anywhere. I have spare metric hardware so I found another one to finish installing the master. I went to start her up to see if I had brakes, and it didn't want to start. Usually once it turns over it hits right away. Then I got the "click, click click" which then turned into NO click! I waited a couple minutes and made sure I was compressing the clutch peal all the way and I was. After a few more tried, it finally turned over and started and then died. It has never done that. I started it with the chock and it stays running, but it will not idle after I turn the chock off, it completely dies. I wondered if that nut ended up somewhere that it is affecting the carburetor linkage. And ugh! We don't have the best weather and I'm limited on days I can drive this thing and I'm spending way too many of those days with it sitting. Any help would be greatly appreciated!
