I hate to ask a tire question.... but
Chapel Hill, NC
Its time to replace the tires that came on my "new" 83 40. I'm running the stock 15x6 rims. I did some searching but found few facts and a lot of opinion, most of which applied to 2.5" inch lifts, which I don't have.
The question is this.... can I safely run 31x10.50 on the stock rims and stock suspension? I'm probably going with BFG ATs as my experience with them has been very good.
I do very little wheeling in this 40.
Thanks!
I run 33x10.5 on my stock steelies, But with the lift.
You might have issues in the rear wheel opening with the wider tires, a 9.5 will fit for sure. The one issue I have had on the 10.5 is I have to run aroudn 28 psi in the tires in order for them to stay flat in the surface patch. So not sure if that helped but there you go.
Dave
Both 9.50 or 10.50 will fit, assuming your springs are not shot.
31 X10.5
That's what I run with a stock setup. No problems for me
