The same thing happened to me at Pismo Dunes. I was too used to my Tacoma, which I rarely need to air down, plus the 60 is a pretty heavy vehicle. 12 psi and a Maxxtraxx is your friend! I may someday spring for front and rear ARB lockers but all the above advice will most likely keep you moving. Glad you are having fun with her.
Thanks for all of the comments and advice.
I don't venture on to sand all that often. Honestly most of my driving, probably like most everyone else's is on pavement. Having said that, I definitely like the "skinnier" tires. I just recently replaced my tires and went back with the same size....33x10.5x15. I would have gone with 9.5 if they were available. I have the 9.5 on my 40 and it drives noticeably better than the 62. The wider tires seem to want to wander in the pavement ruts. Hopefully the skinnier tires also produce better gas mileage and less wear on the front drive line.
87, that's a great memory to have with your family. I love Mexico and my member pic or whatever you call it was taken at Agua Verdi in the Baja. If you ever get down that way it's one of the nicer beaches I've found.
As mentioned, the end game on all of this is a drive to Patagonia. I want to prepare as best I can for any eventuality that I might encounter on that trip. I'd rather get some experience here where I at least know the language. I put in on-board air this week and that should solve the air down/air up issue on sand or even other off road trails. I'm going to get the Maxtrax although I don't know at this point where I am going to carry them. I guess that will necessitate the rear bumper purchase. Damn, this stuff never seems to end. I also really appreciate the input on putting the locker in the back. My mechanic agreed with that so that's where I will start and plan to have that in by the end of the year.
Getting stuck a couple of weeks ago at Pacific City has turned out to be a good thing for me. Like I said.....I didn't bleed over it and it got me off my butt to do things I should have already done anyway.
I'm taking the slooooow comments to heart while in sand while maintaining momentum. Good input on tire pressure as well.
Another thing that I might have discovered and would appreciate input on is this; I tried to winch this stuck pig out of the sand pit I created and the winch pretty much "gave up." When installing the new compressor my mechanic put in the biggest deep cycle marine battery that would fit from Interstate. He said the old battery, also an Interstate was installed in '06 (man....hard to believe). So....if the battery was that old maybe it wasn't supplying full power to the winch thus reducing the pulling power? Does that make sense?? The winch is now pulling from the main starting battery. All of the accessories (refrig at this point) are on the aux battery. I bought a 90w solar panel which will charge the aux battery so I can set up on said Mexican beach for a week and not worry about running out of power.
This is becoming expedition portal material.
I will appreciate your comments about the winch not pulling maybe because of a less than ideal battery.
Thanks everyone.
