I finally started my tear down on my 1/1979 FJ40. (1 Viewer)
steveola
GOLD Star
kentucky
I finally got started on my 1/1979 FJ40. Got the spare, carrier and ambulance doors off. Man there’s a lot of rust. I think I’m just going to take it slow, one rust problem at a time. I’m afraid if I have it sandblasted, it will fall apart. Not much holding it together I don’t think.
If you want to drive it soon , a new 3/4 tub , alu or steel will take less time then cutting and welding all that rust and bondo
I might be doing that. People seem to like Aqualu tubs. I contacted Mike Gozzard, but it’s just a sideline for him and might take a long time to get a FG tub. Plus the Aqualu seem to be well proven. I think if my A pillars are okay, that would work.
Gozzard are very good but it is more work than a 3/4 tub because most of the wiring is in the dash area and also the heater , steering , pedals , switchs and more things you dont need to swap with a 3/4 tub
Very good point. I wonder if anybody has ever experienced galvanic corrosion with an Aqualu tub?
I picked up a used Aqualu tub a few years ago and got a great deal because the PO had not coated it properly and there was galvanic corrosion to the point that I decided to cut out part of the floor pans and weld in new aluminum pieces. I coated and prepared the tub properly and have had no issues at all since then.
Bottom line: if properly coated and installed, I doubt you will have any serious issues with corrosion if you go the Aqualu route.
That’s good to hear. I’m really leaning towards that. The driver’s side cowl/ firewall will need some patching but certainly doable. I would love to find a goos used one, the new ones delivered are a few coins.
I got the hardtop off. Not that bad. Repairable for sure. The b pillar on the driver’s door is mostly bondo. It looks like at least a 3/4 tub is going to be the only real way to make it solid again.
