I don't understand what the previous owner has done with the fuel filter
Panama
Hello everyone !
I love my my rust free (not easy to find in Panama) HZJ80 from 1992, but I am quite an amateur when it comes to Mechanic and I am trying to understand why I have some black smoke above 3000rpm. I need help on this one. I bought a fuel filter that came with a hole on the upper side to plug it, but also holes and the bottom side :
And the one on my LC :
It is also much smaller. I am wondering if it is a problem, like the flow of liquid passing through it not high enough,. Should i buy the same one ? Are there bigger compatible filters ? Or should I put the system back (I don't see the cables for it, but there's an empty connection not far away)). and use the original filter ?
Thanks in advance
So this question is best asked in the diesel section here.
No idea what you bought, but what I see in the engine bay looks factory. Perhaps it's just the wrong filter?
But the diesel section can answer this most accurately.
Oh sorry I am new here. Can I delete this thread ?
no worries
the filter you bought has no provision for sediment/moisture sensor.
be right back with a number for the correct one
apologies for my initial post, my head isn't working correctly
part number for the sediment/moisture float is
84461-60050
I agree with above.
Replace the float switch, and while you're on partsouq, order a clamp for that fuel hose coming out of the filter housing.
Really common for these to suck air in through poorly clamped or poor condition hoses and cause a misfire
I agree with above.
Thanks appreciated ! As There's a lot of work to do on my truck I should also get more parts to save on shipping
