As the title says, I broke the stock carb on my 85 FJ60.
It was idling rough and with low vacuum, and my mechanic said I had "dirt in the carb". He suggested I try to take the top of the carb off and clean it out, before jumping into a pricey rebuild or replacement.
I did just that - first replaced the secondary diaphragm. Road-tested it, and everything was fine, but still idling rough. I then removed the top of the carb, cleaned out the primary and secondary assemblies with carb cleaner on a clean rag, replaced the gasket, reconnected all the hoses, etc., and fired her up.
She started, hesitated, then stalled. Re-started, and she barely sputter, with heavy gas, she barely idled up, and then sputtered some more and stalled out.
Checking the carb after this, gas was dripping out of the carb off the secondary diaphragm and also the small pump to the right of the secondary diaphragm, near the bottom of the carb.
I removed the top of the carb again, checked everything, and put back together, and had the same problem.
Any idea what the heck I did wrong???
