I am about to buy a low mile 1996 1,500 miles away
Discussion in '80-Series Tech' started by 96LX, Jun 19, 2017.
  1. 96LX
    96LX
    48
    Media:
    4
    Albums:
    1
    32
    Feb 10, 2017
    Nebraska
    Hi, I am about to fly 1,500 miles away to pick up a 1996 Land Cruiser with 96,000 miles. I have spoken with the owner a few times. He seems to have taken care of it, and he says he thinks it will make the trip with no problems, however I just want to make sure I am prepared as possible to make it home.
    I have been searching for months for an 80 series and I have been reading through this forum a lot. It seems that the cooling system is a weak point on these. The owner has owned it since 1999 with 33,000 miles and says that he has never changed the head gasket or has had any cooling problems. Shortly after he acquired it, he installed a supercharger and an unspecified OME lift. The supercharger gives me even more anxiety about overheating on the way home. I am taking I-80 home, where it seems the tallest pass is 8,640 ft in Wyoming.
    The truck currently has snow tires on it, he says the other tires will be included.
    1. I am going to call him again this week with my final questions before I fly out, what should I ask him?
    2. What should I bring with me on the plane? (Needs to fit in carry-on)
    3. I am not familiar with snow tires (I use AT's where I live and they work fine for our winters), should I get them swapped out before a bunch of highway driving?
    4. I am not familiar with superchargers, how can I inspect that before purchasing?
    5. Any other suggestions or tips for this fly to buy adventure?
  2. ZackR
    ZackR
    774
    733
    Jul 21, 2015
    Bend, OR
    Snow tires will work but aren't ideal for dry highway driving (soft tread compound will wear out quickly, handling is a bit sloppier). A 1500 mile trip isn't that crazy, get a AAA card, check all of the fluids and go for it.
  3. 2fpower
    2fpower
    8,369
    3,902
    Sep 5, 2007
    lenexa, ks
    2. Take basic tools. check a bag if you have to. I flew to chicago to get one back to KC once, and ended up purchasing tools in a walmart to get it take apart.
    3. you live in nebraska and don't know about snow tires. Hmmmm..
    4. no way to inspect without removal. you could install a boost gauge quickly, to make sure it is producting about 4 - 5 lbs of boost.
    NLXTACY likes this.
  4. riffman12
    riffman12
    286
    216
    Jan 21, 2017
    SF Bay Area
    SLO Nomad, NLXTACY and LC4LIFE like this.
  5. BILT4ME
    BILT4ME
    4,952
    Media:
    3
    Albums:
    2
    5,432
    Nov 9, 2012
    Olathe, KS, USA
    To bring with you on the plane:
    Credit Card
    Insurance Card
    AAA Card (if you have one)
    Driver's License
    Tire Pressure Gauge
    A couple 8" long zip ties
    Extra underwear
    Tyvek Coveralls
    Nitrile gloves
    Flashlight (or headlight)
    Car Phone charger (Make sure the cigarette lighter plug works before you roll)
    Download the 96 FSM (Factory Service Manual) to your phone BEFORE you leave!!!!!!!
    When you get there:
    Go to a local Sears/Ace Hardware/Home Depot/Lowes to buy a basic set of metric tools. Keep them in the package unless you need to use them. Return them to a like store near you when you get home. Also pick up a soft- faced dead-blow hammer, roughly 2 lb.
    Check fluid levels on the following:
    Engine Oil 5W30 or whatever the PO has in it
    Engine Coolant (Should be red or green....NOT brown)
    Front Differential Oil
    Rear Differential Oil
    Transmission Fluid
    Transfer Case Oil
    Front knuckle grease (This is what the zip ties are for)
    Power Steering Fluid (Dexron III)
    Other things to check:
    Tire Pressures (Including the spare)
    Make sure there is a jack, the lug wrench, and the jack crank tools to change a tire
    All lights operation
    Check age on battery
    Grab all tie rods to make sure none are floppy
    Check for windshield washer operation (and fill fluid if necessary)
    Check condition of wiper blades front and rear
    Check the condition of the alternator belts and AC belt. Adjust if necessary
    Total quantity of cup holders
    CHECK THE BOLTS/NUTS ON THE BOTTOM OF THE STEERING ARM ON THE RIGHT SIDE, BOTTOM OF THE KNUCKLE. THESE MUST BE TIGHT AT 72 LB-FT. ALSO CHECK THE LEFT, BUT THE RIGHT SIDE ARE A KNOWN ISSUE.
    Things to stop and pick up before you hit the road:
    Engine Oil at least 2 quart, I would do a 5 quart jug
    (1) gallon 50/50 coolant of the same color the engine already has
    (1) gallon distilled water
    (2) quarts of transmission fluid made for Toyota's or whatever the PO has in there
    Windex and Paper Towels to clean windows inside
    Blinker fluid
    Spare alternator belts (Pick up from a store name brand you have near your home....O'Reilly, NAPA, Etc. so you can return the aftermarket belts unused later)
    Spare SC Belt
    Beer
    Water
    Ice
    Make sure you get a couple phone numbers of members along the route home. Go to the Clubhouse section above and let the local clubs know what you're doing.
    Let someone at home know the route you are planning for home. Pot your route on 'Mud for those of us following it.
    Post the dates of your expected travel so we know to watch for you (or to go rob your house, whichever comes first....)
    Make sure you have 'Mud in your phone as a shortcut. If you need help, post a :RTH Needed, Stranded in XXXXVille, YY..........
    All in all, it sounds like you've got a relatively solid truck with a SC and very low miles.
    Others that are SC owners know specifics about those.... @NLXTACY ????
    Good Luck!
    Where in NE do you call home?
    FJP971, Brimley, namsag and 10 others like this.
  6. allan man
    allan man GOLD Star
    1,938
    817
    Mar 9, 2008
    Las Vegas,Nevada
    I would drive it right away along with the seller and skip the talking around the truck and have the conversation take place while testing it.
    AC on, Freeway,city for as long as you can get away with. Better to find out then before you hand over the cash 15 min on the highway that you have issues. Good luck.
    Funner, NC LX and BILT4ME like this.
  7. Mountainpassing
    Mountainpassing
    157
    Media:
    23
    Albums:
    1
    62
    Nov 12, 2015
    Bellingham WA.
  8. midfat
    midfat
    813
    1,217
    Mar 25, 2013
    Santa Monica, CA
    Have you considered asking a local shop to do a PPI? (Pre Purchase Inspection). Probably cost you $60-100 and give you a solid professional opinion on what items you should be concerned about. If there's nothing significant, I'd cross your heart and hit the highway. If he does find something that's worrisome, get an account on uship.com and pay to have it trucked to your door. Shipping it is always a cheaper option than fixing it along the roadside.
  9. Cruiserdrew
    Cruiserdrew On the way there SILVER Star
    15,293
    4,133
    Mar 15, 2003
    Sacramento, CA
    Where is it located?
    If he has snow tires, look CAREFULLY for rust.
    But it sounds nice.
    You can always stop in Colorado at Slee or Robbie and have them R&R the headgasket.
    But 1500 miles in a Land Cruiser is nothing. Just don't push it hard, watch the temp uphill (agree with obd2 reader) and enjoy.
    Notch likes this.
  10. DanMedeiros
    DanMedeiros
    434
    230
    Jun 4, 2015
    Santa Cruz, CA
    I picked up my LX the exact same way. I flew in. picked up the truck and drove home. Though the truck I bought had every maintenance record for 18 years and had been serviced at SLEE. it also had a scan gauge installed. The one crazy thing was that the side view mirror broke and drove me nuts the whole way home to CA
  11. 96LX
    96LX
    48
    Media:
    4
    Albums:
    1
    32
    Feb 10, 2017
    Nebraska
    Wow, thank you all for the thoughtful replies! This is an awesome forum.
    Thank you for the detailed response, lots of good stuff I will use here! I live in Omaha
    Great idea, and I already have one too, I will add that to my bag
    I have considered that, but I couldn't find any in the area. Admittedly I didn't try very hard.
    It's located in Lake Tahoe, he say's there isn't any rust. I asked about salt on the roads and he said they don't do that where he is to avoid salt draining into the lake. However it will see a ton of salt on the roads where I live, Omaha
    woodsman 44 likes this.
  12. BILT4ME
    BILT4ME
    4,952
    Media:
    3
    Albums:
    2
    5,432
    Nov 9, 2012
    Olathe, KS, USA
    Great!
    I'm in the Kansas City area and we make occasional trips up into west central Iowa. Usually travel through Omaha. Yes, one of the high salt use areas.........
    Good Luck! Maybe we'll catch up some day!
    96LX likes this.
  13. 2fpower
    2fpower
    8,369
    3,902
    Sep 5, 2007
    lenexa, ks
    @BILT4ME what a response!!
    Your aces in my book.
    BILT4ME likes this.
  14. DanMedeiros
    DanMedeiros
    434
    230
    Jun 4, 2015
    Santa Cruz, CA
    Can confirm no salt on the roads in Tahoe
    shocktower likes this.
  15. Cruiserdrew
    15,293
    4,133
    Mar 15, 2003
    Sacramento, CA
    Northern California is generally not bad for rust. Sounds like you're getting a nice 80 and soon to be the nicest one in Iowa. Maybe you should get a local beater and not drive the nice 80 in the salt slush!
    Have a great trip. I-80 across Nevada has an undeserved reputation for being boring. I personally like it and the range after range of mountains.
    GeoRoss, 96LX and NLXTACY like this.
  16. 2 E L O
    2 E L O SILVER Star
    1,206
    313
    Aug 4, 2011
    Western Nebraska
    I live in Sidney, Nebraska--about 60 miles from the Wyoming border on I-80. If you need to stop for any repairs PM me and you can use my garage/tools/beer. Good luck!
    Hornd and 96LX like this.
  17. woodsman 44
    woodsman 44
    702
    1,242
    May 7, 2008
    nor cal
    With only 96K miles, Id just drive it like u stole it...;)
  18. woodsman 44
    woodsman 44
    702
    1,242
    May 7, 2008
    nor cal
    Oh, and yes, Tahoe does not salt roads....Im up there all the time...enjoy your trip back!
  19. lcgeek
    lcgeek Glad to meet you!
    985
    Media:
    1
    749
    Dec 26, 2005
    Goodyear, AZ
    Wait - you haven't closed the deal on a low miles super-charged 80 and you are posting here on MUD? :poof::poof::poof:
    Funner likes this.
  20. PDoyle
    PDoyle
    2,227
    Media:
    13
    Albums:
    1
    119
    Oct 5, 2003
    Saratoga Lake, NY
    Damn you guys set him up! Congrats! Don't tell anybody where your picking it up. There would be a line of guys looking for it.
    Make sure the spare tire cranks down to the ground.
    Driving with snow tires is ok until you get the 5 tires you want IMO.
