Hi, I have a hzj79l pick-up with dual fuel tanks.
The problem is that the truck loses power intermittently on the main tank. When I switch over to the sub-tank the truck goes like a train!
Most obvious things have been checked including things that would probably affect both tanks, for example fuel filter checked/changed, screen on injector pump checked/cleaned, fuel filter primed in case of air.
The truck uses 2 solenoid valves on the chassis just to the right of one of the tanks. I've checked the pipes and vent going from the problem tank to the solenoid valves and they appear to be free of blockages. The tank has also been drained twice.
None of this has improved the problem in the slightest and I still am not sure how the damn fuel systems works!!!
Does these tanks have an internal electrical pump or just a level meter (if so could be pump fault)? Or, do the solenoid "valves" also have a small pump integrated? How do I check if the solenoid valves are working correctly (these are actually the only things I haven't had time to take out and clean)?
Is there anything else I am missing?
Cheers, Mike
Cheers, Mike
