Hzj75 series shocks with adjustment. What are my options?
Holstebro, Denmark
I have been looking a bit online but are having trouble figuring out what my options are.
I need some shocks where I can adjust the resistance to fit my WAY to heavy camper.
Maybe even both compression and rebound.
What do you think... Do I need to be able to adjust both?
My local 4x4 shop recommend Terrain Tamer res 8 stage for 50mm lift ? (SEE PHOTO)
Any other suggestions?
If you are in Europe, you may consider getting in touch with JRZ suspension in Holand, I have used them on several projects with several different series of shocks (single tube, double tube, adjustable and set types) they also have steel and aluminum bodies.
If I remember correctly their fully adjustable shocks have 24 set points both ways (rebound and compression).
I know they have designs for recent 70 series, but not sure if they have any designs for earlier models.
From what I remember, their adjustable range is very wide (force vs speed) with their valving.
Good luck
