I am trying to figure out a few things for my dad who might buy a HZJ73.
I know the 1HZ engine is a good reliable engine that is quite compareable to the 1hd-t.
from what i know you have to change the bottom end bearings. am i right?
As far as I know there is no known issue with the bottom-end bearings like the first HD-T. As a precaution you can replace them if you're unsure about the quality of servicing in the past.
My 1HZ has done 250k km's at the moment, with a lot of towing a heavy trailer and doing some off-roading including deserts. There is no indication that there is a problem with the bottom-end bearings. Service-interval (engine oil) is somewhere in between 5000 and 7500 k's depending on conditions, drivetrain is at 15000 to 25000 depending on conditions eventually shorter interval (deserttrip, water-crossings)
Is the whole truck run on a 24 volt system or does it have the funny cross over system like the hdj81?
Are the headlights 24 volt?
At least min is fully 24V (European version) don't know about other versions.
whats somethings i should look out for on those trucks?
Rust. Look at the edges of the front wings where they meet the wheel wells. The seams tend to rust.
Behind the door-opening and rear wheel well and rearend near wheelwell and rear lights.
When I bought my rig ( it was not new, about half a year old) I found standing water in those areas. These should be drained by small holes which tend to clogg. I used the tip of a tight-wrap to open up these holes that look like small gaps between the welded body parts. Later I drilled holes in the bottom of those areas and protected the blank metal resulting from the drilling with a good quality rust-prevention goo.
Frontwindow frame rust. The front window frames tend to rust from inside.
If you search this forum you'll find some related postings.
