HZJ73 - Finally!
North Okanagan, BC
I've been reading the board, and watching whats going on, but haven't posted lately 'cuz I haven't had anything to say/report.
Well, I finally picked up the HZJ73 that I committed to in June :bounce2: :bounce: :bounce2: - three months later than when it was supposed to be here. 'Twas a little bit scary driving a RHD for the first time in the dark in Kits, on Halloween......
The L/C was quite lifted (Appears to be after market springs, and a shackle lift), with a big roof box - it was overheight for several ships, and was moved to the back of the line on more than one occasion. The over-all condition of the truck is excellent, but a little stained in the interior from smoking.. The PO had the roof box and a light bar on top, with just about the poorest wiring job ever seen - the wires for the lights were just laying on the roof, and buffeted in the wind at about 110 K. Due to the shackle lift, the 'Cruiser bump steered quite severely, and really wallowed in the corners.
Last night, the roof box came off, along with the light bar, monsoon vents, tacky 24V cup holder cooler/warmer (It was screwed in front of an A/C vent, to cool your drink, and it has a heating element that is supposed to heat your drink when you turn it on - but that doesn't work)
This morning, the shackles were lowered to a more proper length, resulting in a 1" drop to the front, and a 2" drop to the back. Handling has improved dramatically, and the bump steer has all but disappeared. We then headed to Kelowna to pick up a receiver hitch from Princess Auto.
While wandering around the P/A store, looking for 24V light bulbs (none to be found) and marine style cup holders, I found a relay box for wiring two element trailer lights from three element vehicle lights.. The strange thing was, there is a separate power lead to the relay box!!! Guessing at what the circuitry must be, I purchased one for the whooping sum of $12.99, (it came with a 4 ft. trailer connector, and about a 20 ft. power lead).... I've just jury rigged and tested it , with 12V to the power lead, and putting 24V to the inputs, the outputs give 12V, as I hoped!!!! Now, the green smoke didn't leak out when I put the 24V to the inputs, but to play it safe I'm going to put some dropping resisitors in series, to reduce the input current.. Thought you guys would like to know! BTW - this relay box was in the "Surplus" section of P/A, and the Kelowna store had about 20 in stock.
A few questions regarding the HZJ -
1) The L/C has headlight washers with a separate reservoir, but I can't find any button or switch to turn them on. Are they supposed to spray with the windshield washers, when the headlights are turned on? or am I missing something?
2) There is a red button in front of the automatic shifter - probably an Overdrive/lock-up switch, but it doesn't change anything when I push it. There is a buch of Japanese writing near it, but........................
3) I'm from the old school of 4x4's - I only trust manual hubs and transfer cases where a lever on the floor does the deed. My distrust of Automatic hubs is seems to be with reason - the hubs do not appear to be engaging, but further testing will be required.. Are there manual hubs available for to replace the Autos? - for a 8" high pinion? Will mini-truck hubs work?
Jim
head light washers only work when headlights are on and you use the regular windscreen washer switch.
the red button is for when the key is out and you want to shift from P to N or any other gear.
the electric hubs are fine, the ones i have been using have not failed yet and this is with running in ice water off and on for 6 hours. how did you determine they were not working?
HTHs
cheers
That relay circuitry might be similar to what Bruce and I came up with in an earlier thread...check the FAQ for this thread. We did use 24V relays, though...and I'm guessing that yours probably has 12V relays in it, so you would probably be right in putting resistor inline to the inputs. The power lead would take a 12V input in order to put out 12V to your trailer, unless you want to keep everything 24V.
Can't wait to see the pics! Congrats. :beer:
Wayne:
Thanks for the info, that gives me a place to go looking/trouble shooting for the headlight washers - one of the windshield washer jets is plugged also, so it may just be crud, or an electrical challenge.
The shifter button functionality is something that I would never have thought of.
My initial "test" in four wheel drive involved trying to climb a steep bank, and the rear end just dug in (and only one tire - it's 'sposed to have a posi in the rear), with no spinning of the front tires. So either a hub is not locked, or the transfer case is not "transfering". I'd much rather deal with hubs than the transfer case! Being electrical, and seeing the stuff the PO did, that'll be the first place I'll look. It would be handy to have a chassis wiring schematic - know where I can find one?
Stone:
Exactly my point - except for $12.99 and no messing around with a custom circuit, it's a much easier/cheaper solution than rounding up 24V relays, and doing the wiring. I'll buy a spare next time I'm through Kelowna, and if anybody else wants one, let me know. My intent is to run the power lead off of one battery (12V) and leave everything on the trailer as is. - I use my trailer about twice a month to make a trip to the dump, or to pick up building suppliers etc.. (BTW, The trailer was built 25 years ago to pull behind my FJ40, it needs refurbishing/sandblasting/repainting, but people always comment about the 31.5x10.5 Mud T/A's that are on it!!)
One of the surprises with the L/C is that it came with virtually 100% 31x10.50 Blizzaks, and a 90%? 33 x 10.50 BFG A/T as a spare. My intent was to run a 16" Blizzak or X-Ice for the winter and run a 33x9.50 A/T in the summer. I don't have to worry about winters now, only a set of steel wheels..
I'll try to get pictures up tomorrow.
Jim
Jim, lock the hubs and jack up the front end and turn a wheel. the front driveshaft should be turning. if this is hte case then the t/case vacum shift is acting up...
cheers
Jim_Hbar said:
Wayne:
Jim
Here's the chassis manual for 70 series cruisers. The manual itself is in french, but the wiring diagrams at the back (around page 370) are a mixture of french and english. Some of the labels are french, but as far as I can tell, things like the wire colours are english. There are digrams for the HD and LD cruisers, so make sure you're looking at the right one. This is a 1990 manual.
http://repairmanual.free.fr/manuel_chassis_serie7_1990.pdf
Also, check this out. It's in english. May be of some use.
http://perso.wanadoo.fr/adherence_4x4/serie7_elec.htm
hth's
Robin
Hi Jim,
Congrats!
I have noticed on my BJ74 that the clearance between my stock spare tire and the rear bumper is just over an inch. I assume you have a stock rear bumper and mount. How does the 33" fit and what is the clearance like?
This is one issue holding me back from 33" tires. There is also the issue of weight on the rear door hinges. Allstone has suggested a custom swing mount.
Thanks,
Bruce:
My L/C came with about a 12 " wide platform mounted off of the rear of the frame - no bumper. The platform has dissappeared now, so there are no clearance issues with the 33 on the door...
However, the lower hinge appears to be worn........ :eek:
Wayne:
It is definately the hubs that are the issue - front drive shaft turns when 4HI is engaged, and doesn't when the hubs only are locked. When I jacked up the left side and rotated the tire, I heard the "click" of that hub engaging, so prime suspect is the right side hub.
Jim
good diagnosis, it might be a simple fix... or go to manual hubs....
Wayne:
Went out to the shop tonight with my wife as a helper. Had her turn the hubs on and off - definately the front right hub - wuzn't making any noise. Tested external connections, and it wasn't external to the hub.
1) Took the hub apart, and had power right to the slip rings. The brushes were all greasy, so cleaned them up.
2) Powered up the brushes, and the motor worked.
3) Slipped the hub right back on the studs - expected a problem with the brushes going on the armature - no issue what-so-ever.
4) Had the boss cycle the hubs - nothing. Brushes weren't making contact!!!!
5) Added some "set" to the brushes, and observed the hole drilled for assembly. Inserted a wire, and slipped the hub on the studs - tested - not enough set.
6) Repeated (5) and tested - works now!
Reassembled and tested - still works!
I'll keep them for now, but they seem like they were designed by Disney! Where can one source "real" hubs?
Thanks for your help!
Jim
Jim,
i have not pulled the elec off yet so i can not tellyou if they are Land Cruiser hubs or Mini hubs. i would suspect Mini but it is juat a guess at this time.
sorry
Thanks for the pics.
Not bad. How much for the tire/jerry can set up?
Bruce
Update on the HZJ73
When I initially picked the LC up, Outback was having a challenge getting delivery of the BEB's, so they made a commitment to change them at my earliest convenience after I took delivery.. (BTW - you can put another engine on the OKAY list)
First trip back from Vancouver, up the Coquihalla through Kamloops to Salmon Arm resulted in fuel consumption slightly under 7 km/liter. The truck cruised along the highway quite nicely at 110 to 120 kmh, and was surprisingly comfortable and quiet, but any slight grade on the highway resulted in a drop in speed down to about 90 kmh.... I was somewhat disappointed with the fuel consumption and the power, but suspected an injector problem - due to the smoke on the hills.
Drove the LC around town for a couple of weeks, and as I drove it I noticed that I was getting less smoke climbing the hills back to the house. We were invited down to Vancouver for the Nov 11 weekend, so I spoke with Outback, and they were ready to do the bearings on Monday. We headed to the coast, travelling along nicely at 110 km/h typically - I remembered Wayne's comment about 150 kmh not being likely in a non-turbo 1HZ, so I gave her a little try! It was still accelerating nicely at 140 on the flat - I believe it would do an indicated 150 easily (on the flat). BTW, with the torque converter locked in fourth, I run 2000 RPM at an indicated 100 km/h. Coming down the hill to the snow shed, I got a real surprise! Lifted at the top of the hill at about 115, and made it about half way down, and noticed something very strange! The truck was now down to 90 kmh!!! Every other vehicle that I have ever driven on that hill would be up past 140 at that point, if you hadn't touched the brakes. Drove around Van. for the weekend, had the bearings changed on Monday, and back out Monday evening. Filled up in Surrey - almost 9 km/liter on that tank....Hmmm...
Drove the Coquihalla back in the dark - noticed that the truck no longer slowed down on any grade on the freeway out to Hope. Pulled most hills fine, but was still down to 75 (2nd, 3000 rpm) to 80 (pulling hard in third) - kicked the hubs in at the top of the hill, and drove to the toll booth and past with the hubs engaged, and was in 4HI for about 1/4 of the time. Got home and checked the fuel comsumption - 8.5 km/liter.
Some of the differance in fuel consumption can be attributed to my driving habits - initially I did not have the engine figured out, and it does have some strange charateristics. Things that I have observed about the stock installation:
- It is pointless reving the 1HZ much beyond 3000 rpm, even though the red-line is at 4500 rpm - better beformance is to had by shifting up. (The engine seems to run out of steam - too restrictive of an exhaust, and/or, not enough air in) - it needs a turbo!
- The peak torque of the engine is supposed to be at 2200 rpm - I'd have to agree! You drive along the highway at speed, say 100 to 110 kmh (2000 to 2200 rpm) and a hill presents itself - one of two things happens; either the LC goes up it without a change in throttle position or engine note, or, the tach and the speedometer start heading for the basement! And it isn't like a gasser where as the hill gets stepper, the rate of acceleration changes.. It's like the 1HZ says "Nope - too steep, I'm not going to do it in that gear" And dropping a gear doesn't do much either - (see the above point). It needs a turbo!
- If the engine isn't pulling the hill with the current throttle setting, and you push down and the performance does not increase, you may as well back off and downshift. It needs a turbo!
- A HZJ73 with an automatic makes a fantastic city vehicle! There is always an empty spot in traffic for you - and it's short enough to park - people don't try any of that big city intimidation schmitt on you! example - I was driving up Howe Saturday afternoon, and a taxi comes out from a hotel - he sees me and my winch bumper c/w brush bar and STOPS! There was more than enough room for him to pull out, and if I was driving my Accord, he would have pulled out with half the room in front of me. However, I don't see where a turbo would help here:confused: but it probably would!
- There is no issue keeping up with traffic in normal situations, but highway merging would be a bit better if it had a turbo.
I've been out running the net - reading, researching, and looking at turbo maps - I've done some tentative sizing and selection, and my next step is to dig out the text books and see if the web sites are talking trash or not. After that, I'll talk to some turbo shops/vendors for specific models. From the information that I have found so far the T04B-S3 looks like the ticket for the 1HZ, or, for about three times the price, the so called "Disco Potato" appears to work well also (I'm a little leary of the only turbo that has a nickname)
So, if any of you guys have any specific contact information, or reliable vendors to deal with, please jump in.
Jim
Ens Industrial can supply English language factory service manuals for the 1HZ and 70 Series trucks.
crushers said:
Jim,
sorry
I thought the mini hubs and cruisers hubs for thoses years are the same?? I only say that because I bought a set of mini hubs off of ebay and they were identical to my cruiser hubs from 84 on.
Putting regular hubs on in place of the e-ones you will not have 2 of the 6 bolts those holes are used for the power to the e-ones.
Cheers,
Michael
