HZJ-73 24v Light circuit
edwajon
10 Year 15 Year
Raglan.NZ
Guys, anybody got a circuit diagram for a 24v main head lights as i am blind in one eye , and wondered if there are relays for each head light? By the way bulbs are fine.....
Regards..Jon
Have you looked at the ONLINE manuals to find diagrams?
According my manual there's only one relay involved. From that relay TWO fuses (10A each) feed the lights. Then the 'negative' leads are fed to the high/low switch and then to ground.
That's for the none European version.
The European version is lightly different as that the positive is switched. And it's two relays that are used, one to switch lights OFF/ON and the second one for HIGH/LOW. From this relay FOUR fuses are fed. Two for high and two for low beam.
So in both instances both headlights are fed from the same relay.
There must be a problem in the contacts/wiring/fuses if the bulbs themselves are good.
Thanks , for that managed to get the correct download from the link supplied by this Forum , thanks for the help I will check it out and let you know ,whats going on here
